can someone tell me why when i run a g29 command, the probe does not stop the bed from crashing into my probe?
my probe will stop the bed from moving closer to it during octoprint manual movements. so it is setup correctly as a endstop based on that.
but during a g29 its just not working as it should. the probe is on, the light turns on as the bed is hitting it. strangely the x/y movements are super fast, yet the g32 is supposed to slow it down i thought with the s-60?
i suppose the problem could be the g31 commands at the end of each probe, then its homing z? so its docking my probe then homing z? i guess maybe thats fine on a normal printer but im on core xy so…yah fun times. maybe it has to do with where my hard endstop is located? i have it at the min then use a offset to not smash my nozzle. seemed the most logical because if i had it at max then it would take 5 mins every time it homes to get back and forth. anyways how to i get this to work
[Macros]
g31 =
M106 P2 S0 ; Turn off power to probe.
M574 Z2 ; Probe up (Dock sled)
M280 P0 S320 F3000 ; Probe up (dock sled)
g32 =
M106 P2 S255 ; Turn on power to probe.
M574 Z2 z_ccw, h_ccw ; Probe down (Undock sled)
M280 P0 S-60 F3000 ; Probe down (Undock sled)
g29 =
M561 ; Reset the bed level matrix
M557 P0 X10 Y0 ; Set probe point 0
M557 P1 X10 Y180 ; Set probe point 1
M557 P2 X180 Y180 ; Set probe point 2
M557 P3 X180 Y0 ; Set probe point 3
M557 P4 X90 Y90 ; Set probe point 4
G28 X0 Y0 ; Home X Y
G28 Z0 ; Home Z
G0 Z12 ; Move Z up to allow space for probe
G32 ; Undock probe
G92 Z0 ; Reset Z height to 0
G30 P0 S ; Probe point 0
G0 Z0 ; Move the Z up
G31 ; Dock probe
G28 Z0 ; Home Z
G32 ; Undock probe
G30 P1 S ; Probe point 1
G31 ; Dock probe
G28 Z0 ; Home Z
G32 ; Undock probe
G30 P2 S ; Probe point 2
G31 ; Dock probe
G28 Z0 ; Home Z
G32 ; Undock probe
G30 P3 S ; Probe point 3
G31 ; Dock probe
G28 Z0 ; Home Z
G32 ; Undock probe
G30 P4 S ; Probe point 4
G31 ; Dock probe
M561 U; (RFS) Update the matrix based on probe data
M561 S; Show the current matrix
M500; (RFS) Save data
[Steppers]
microstepping_x = 6
microstepping_y = 6
microstepping_z = 6
microstepping_e = 6
microstepping_h = 6
current_x = 0.5
current_y = 0.5
current_z = 0.5
current_e = 0.5
current_h = 0.5
steps_pr_mm_x = 10.0
steps_pr_mm_y = 10.0
steps_pr_mm_z = 50.0
steps_pr_mm_e = 26.15
steps_pr_mm_h = 50.0
in_use_h = True
slave_z = H
direction_z = -1
direction_h = -1
direction_x = -1
direction_y = -1
[Endstops]
invert_x1 = False
invert_x2 = True
invert_y1 = False
invert_y2 = True
invert_z1 = False
invert_z2 = True
end_stop_z1_stops = z_ccw, h_ccw
end_stop_z2_stops = z_ccw, h_ccw
end_stop_x1_stops = x_ccw, y_ccw
end_stop_y1_stops = x_ccw, y_cw
[Heaters]
sensor_e = SEMITEC-104GT-2
max_temp_e = 270.0
[Cold-ends]
connect-therm-e-fan-0 = True
add-fan-0-to-m106 = True
[Planner]
max_speed_x = 0.3
max_speed_y = 0.3
max_speed_z = 0.03
max_speed_e = 0.2
max_speed_h = 0.03
acceleration_x = 3.0
acceleration_y = 3.0
acceleration_z = 1.0
acceleration_e = 3.0
acceleration_h = 1.0
[Homing]
home_speed_x = 0.1
home_speed_y = 0.1
home_speed_z = 0.1
home_speed_e = 0.01
home_speed_h = 0.1
home_x = 0.00
home_y = 0.00
home_z = 0.00
[Geometry]
axis_config = 2
travel_x = 0.216
travel_y = 0.203
travel_z = 0.4
offset_x = 0.0
offset_y = 0.0
offset_z = 0.0025
[Probe]
length = 0.01
speed = 0.05
accel = 0.1
offset_x = 0.023
offset_y = -0.004
