the mosfet you are connecting to L should have its output connected to ground so that when it changes state it grounds out the L signal. right everyone or am i crazy?
The mosfet your using should SWITCH to ground.
Confused why are you referencing smoothie when you are using Ramps/Mega?
My query above asked for the voltage on D8 not continuity??
There is no voltage on D8. I was measuring continuity to see if the MOSFET switched, but didnt see evidence that it did.
What ive done today is connect both power supplies to the RAMPS with no other connections (so the LEDS would light) and found that an M3 command did not switch Q3 at all.
I then looked at the code and it appears that the cpu_map is wrong as i managed to switch Q2 with an M3 code. Ive now changed the code and have an M3 switching Q3, which when connected to LPS L, turns the laser on, and is PWM controllable.
Using laserGRBL software I can M3 S1000 to get full power, S500 gives 50% etc, with maximum power being set on the front panel pot. In short, exactly what i was trying to achieve.
Hey Dan, I’m working with an identical issue and was wondering if you could upload the pin mapping and other changes you made to connect D8 to your L fire control in line with your pot. I’ve gone back and forth between Marlin and Grbl, and like you decided GRBL mega 5x was better suited for lasering. This is the last thing I want to nail down before I fire it up.
