Can someone give little help what is wrong PID tune on smoothieware software. Before that marlin and mega2560 works brilliant, but now i dont get any good values auto pid to my printer.
I try different temps etc, but not help. Auto-tune gives me this kind of pid tunes:
e3d v6 hotend with 12volts.
Always temperature goes ok but “braking” too much and leave 2-3degrees under setpoint and ever reach that setpoint. If wait long printer goes HALT state.
Any tips or are smoothieware some known bug on autotune procedure?
@Arthur_Wolf hi Arthur. Can you tell is some temperature tolerance on hotend when printing is going. Now i get my temp nearly right that goes 253.5-254.5degrees whole time on print. Last time goes 252-253degrees.
Is there some 2degrees tolerance etc if printer is out that tolerance example 15min printer goes HALT state?
@LassiVVV This post explains PID tuning pretty well without getting too technical: http://forum.seemecnc.com/viewtopic.php?t=11440
I’m having similar problems as you getting printer HALTs when the hotend can’t maintain temperature. Look for thermal runaway settings in the link that Arthur posted above.
