Good idea… Would one board per 2 strings/motors make sense? It fits well with the motor control board layout.
so all the wiring from a daughter board to the main board could go over a single serial connection? Easier from a wiring perspective for sure…
I will… my understanding was that for my application a PID motor would work better than a stepper, but regardless, it will be helpful to look at how the serial protocol works.
Edit: looks like he is using it as a servo after all… and that is the exact setup of my motor, except I didn’t have to add my own encoder. I like how he fit the control board in the same case with the motor. very compact… Reading about ‘backlash’ in the comments, I’m not sure I understand what that is exactly… I’ll have to read up on that. Does PID account for that?
reading this: XMoto DC as Servomotor | Details | Hackaday.io I’m wondering if this is not the same motor I have after all. It looks the same, but this is a ‘high power’ version, probably not available with a built-in encoder… this one will take 1.6A, and IIRC the one I ordered takes 500ma. Presumably, if the one I got doesn’t have enough power, I can go this route. This post is only 4 days old, so I’ll be following with interest!
If this solution doesn’t have the torque needed, I’ll probably be looking at a worm gear motor like that. 8 of those would take up a lot of space, though, so I’m hoping the smaller motor works. And the rpms are pretty low for my application, although some of them may get close enough.
