Bonjour à tous, je me suis acheté le modèle vevor 50w CO2 30X50 cm.
J’ai plusieurs questions.
Quel format de fichier pour ouvrir depuis une clé USB ?
Il doit avoir une erreur car mes textes sont gravés en miroir (axe inversé)
Hello everyone, I bought myself the vevor 50w CO2 30X50 cm model. I have many questions. What file format to open from a USB key? It must have an error because my texts are engraved in the mirror (reversed axis)
Have a look at your “Origin”. I have found if I have the origin swapped then it ends up mirrored in LightBurn. I have 2 machine profiles in LightBurn which have different home positions, Ortur: front, left verses K40: left, rear and when I open a design but forget to set the correct machine, I’ll get mirrored results showing.
I recently acquired basically the same 50W laser, so I’m still working though things. I’m using lightburn to control my laser so I haven’t needed to play with using the USB flash port, but I’ll see if I can help you.
What controller does your laser have? For instance, mine has a KT332N controller.
