best computer program to run with a stock K40 and moshidraw…windows 98…2000…xp… or windows 7…thanks
I run windows 7 64 bit ,works fine-computer specs are and quad core 2.7Ghz,8 gig ram,cheap graphics card that alowws me tual monitors,
I use corlel draw x7 and nornaly only have to import a bitmap of what i want to cut then convert it to 2bit color ,than outline trace and i have my file ready to cut ,takes 2minutes to do if i have no editi g to do on bitmap.
I mainly cut scrapbooking emblums using 3mm mdf
I run an old XP machine and use Illustrator CS2.
Win 7 64 bit, 8 GB ram, core duo e8400. I mainly use corellaser (the initial learning curve was annoying, was a little stuck in my ways…) I also have CS4 Illustrator on there for when I come across files that corel won’t natively open.
