I have 4 meter long strips I will check the voltage drop and let you know. I personally do not experience issue but the grounds of each sides are linked (otherwise noise)
But one thing for sure at white max brightness you will push 29A through each strip.
replace the power cable of the strips by something larger in diameter
following ohm’s law the more current the faster the voltage drop
I would inject power at least in the middle at least to reduce the current in the strip.
make sure that you have large capacitor at the power entry of each strip to avoid to ‘burn’ them when powering on
