Anyone here who receives DMX data with a Teensy AND controls leds at the “same time”?
Is this a way to go when aiming for high fps numbers?
Which hardware did you use? MAX485, SN75176?
I’d be happy to read about first hand experiences.
Hi @Stefan_Petrick I’m just playing with max485 now, but not ready for testing yet.
Which library have you used?
Also side note, playing with <140m cable>
I want to synchronise several teensy over a large distance. WiFi was too lagged. So, now looking at DMX/RS485 (not modbus).
DMX and high Fps in the same sentence? If you are using a full DMX universe (512 bytes) - you’re going to be capped at approximately 44fps.
Better to use DMX to send control messaging but have actual frame data computed on the fly on the Arduino/teensy you have connected to your lights.
Yes, @Daniel_Garcia of course it is only about sending control parameters and computing the actual animation on the µC. Thanks for answering my implicit question how long the transmission takes.
Yeah, DMX runs at, I want to say, 250kbps (aka about 1/3rd the ws2812b data rate)
