Alex, really! I think a lot of OX machines run using tinyg and chilipeppr.seems to me that one of our members might have encountered the problem and would have an answer. I thought the this group was established to help OX users, not selectively answer questions about only certain components of a complete system.
John, thanks for your response.
OX users, currently you cannot use the chilipeppr widget to set tinyg parameters or to save and restore such settings.
Ted
Originally shared by Dennis Espinosa
Hi Everyone! My chilippepr + tinyg setup just bump into a minor problem. It is working fine projects after projects, actually its working great now, the only problem is when i click the “configure tinyg settings” button i dont get to see the pop up settings bar where i could change some settings. What i get is a “edit in jsfiddle” shortcut bar in which when i click it, it goes to the jsfiddle code or something. I am not familiar with coding and stuff so it puzzles me. I will include some screencaps for you to check. What i need is the pop up settings bar to be back and its all fine.
Thank you.
