Hello everyone.
I built a diode laser engraver and used a DLC32 V2.1 with a Neje 40630.
It works but when I launch an engraving, at each beginning of a letter (I wrote a text), the laser stops lit on the first point as if it were letting the cutter cool and then leaves for the engraving. Result: beautiful writing but all the letters with a large initial dot.
I checked the command $32 Laser-mode enable which is set to 1, but even at 0 it doesn’t change the situation.
Could anyone help me?
Thank you
Make sure your gcode generator is using a M4
command to turn the laser on, It is probably using M3
since this is often the default. Make sure this is set correctly in the ‘start’ gcode. There may be a specific option for this in your settings.
edit: removed a comment about M5
In short; GRBL’s laser mode only applies when the laser is enabled via a M4
command.
This sounds like there is either a dwell (‘G4’) command in your code before every path, OR like it is actually code for a CNC (3-axis) machine that includes plunge and retract moves between every path segment.
Again, look to your gcode generator settings.
