Thank you for accepting me. I’m a newbie in the world of laser cutting and engraving. I have the above laser cutter / engraver but have lost the usb driver supplied with it. Can anyone point me to the right direction where I can get it from please? Also I would like to use light burn with it but the softwarre is not picking up the laser cutter. Which would be the closest comparable set up can I choose to make it work please. Many thanks
Can you post a picture of the controller board and the front/top control panel?
With that we should know what controller in on the machine and the firmware on that will determine which software choices you have.
