(1) 0.9 or 1.8 deg?
(2) Robotdigg ones obviously work but is there anything to be gained by paying a bit more for something of supposedly better quality?
If it matters I’m more interested in print quality than high printing speeds.
0.9 (400 steps per revolution) is better than 1.8 (200 steps), but 1.8 is most common. You must look at the others specs, like holding torque, speed, …
It depends on your need, I’ve got some cheap Chinese from Aliexpress and they work fine, but better quality will have better control (more precise), less chance of skipping step, specs will be more “actually” what is the stepper is, might run cooler, etc… but does it worth it? I don’t know…
@Oliver_Seiler Could you please explain more about gearing the motors down? (how/why etc). Conscious I have gone for 10mm cross rods and will probably go for a direct drive so will be trying to move a fair bit of weight around. Sounds like a good option just to start with 1.8 degree Robotdiggs.
@Julian_Dirks I don’t think it’s really required, if I remember correctly I had a few carbon fibre infused PET prints with skipped steps. PET-CF tends to build up filament on the nozzle a fair bit, so I wanted a little more grunt. I’ve simply replaced the pulleys on the motor/rods with 20/40 (or 16/32) teeth ones
I could never get the silicone socks to works properly, they always got in the way at some point. Maybe time to try again,thanks for the reminder @Walter_Hsiao
Yeah, they don’t attach very securely, it may be worth using kapton or wire to secure them. I also find they block airflow around the nozzle so I don’t use them with PLA, but I usually put them on if I’m doing a medium or large PETG print.
@Sebastien_Plante I am local to the seller and have used those motors and some of their other products on other projects too.Though, I am having my own issues right now, I am pretty sure its not the motors.
+Oli@Oliver_Seiler I put a couple of wraps of 4mm kapton tape around the sock a the top to keep the ears from falling away from the heater block so that the lips stay engaged. Seems to work pretty good and easily removable and replaceable.
Thanks for the advice. I’ve ordered the 1.8 Deg steppers from Automation technologies in the US mainly because of freight. Robotdigg was going to be US$38 freight for $30 worth of steppers. To be fair they’re heavy things but even freight from E3D in the UK (pretty much the polar opposite to NZ) was cheaper than RD.
