Had to share this. Amazing bit of design.
Thinking of making a clock from it.
just … wow!
Very cool project, well thought out.
How are you planning on doing a clock? Daisy chaining 4 or 5 of these together, as each completes its cycle incrementing the next?
How about the actual timing mechanism which sends increment signal to first counter?
Again, very cool project
I’m thinking of making 4 of them but slightly changing the design. I’d loose the spring for the ratchet, and redesign the cam shaft with the screw to fit directly onto a cheap stepper. Control those with arduino.
Very neat and nice design.
Would like to see a clock made with it ![]()
So, are you going to modify your 4 units so that
Are you planning on only using the stepper on the first unit, and then some other mechanism which increments each successive unit as each unit circles back, or are you thinking of applying the stepper to all 4 units
I’ll make it a 24 hour display, with steppers on each unit.
I was only thinking about it - guess I’ll have to make it now ![]()
