2560Pixel ESP32 WiFiartnet + SDcard-readwrite and RTC
use Jinx or Glediator to display your animations and control all with your smartphone over Blynk
With the great help of Yves Bazin i did this amazing project!
Saved animations and patterns can be displayed on the LED screen. The moving patterns are saved on a SD card via Artnetwifi which can than be played back from a SD-card. With a software it´s possible to transmit live animations directly to the LED screen. The time can also be displayed on the screen. The screen is controllable by a mobile phone (IOS, Android). Control the brightness, patterns and mode selections, clock while a displayed animation are possible.
I am open for every idea or improvements to the code. If you wanna see more of my artobjects you are welcome to visit my homepage: https://kunstkraft.jimdo.com/
Nice. Did you use 16x16 matrices put together, or did you lay LED strips?
Also, I haven’t played with artnet yet, what are its main advantages and possibly drawbacks?
@Yves_BAZIN Thanks again … without your help this project would never have been as great!
@Marc_MERLIN this are 10 pieces of 16*16 matrices. i think they look better, are less work and are not much expensive than strips.
the best thing with artnet is you can do all you want (animations, gifs, videos,…) with an external software or you record the stuff on a sd-card. and i think it needs not as much cpu power as the controller would render effect-programs out of itself. the drawbacks i would say the recorded animations need much space for few seconds a few Mb. and records are not as flexibel, if you want to make changes on the fly …than you will need a controllersoftware.
@Stef_Weicks Super! What ESP board did you used? Some how i get an SPI error about digitalpin blablabla compiling it on an Wemos lolin 32 pro with sd card reader. Need to try it on the esp32 dev kit board and fix a sdcard reader
i fixed also a bug with this real time clock…i think its because of the two wire. it also makes some problems with short flashes in the animations. therefore i took the RTClib which is much better… i have to test …
maybe later i have time to upload a new version.
@Stef_Weicks sketch cant connect to blynk.
can i bypass the blynk app and use/ assign GPIO’s to start recording and stop recording data? or by entering value’s in serial monitor?
