1st print using a modified version of GCodeSimulator on an Android Tablet over USB OTG cable. It works !!!
Can you elaborate, what is the benefit ? Does this replace a PC ?
@Shachar_Weis it indeed does. It takes over the need to have a PC attached in order to print. So does an SD-card and a panel, but this is much cooler, because you can slice your objects on it too.
Awesome, do you have any links to more info or source code?
Nice, where do we find the code for this. This is interesting.
