I use the tinygtablet version of Chilipeppr, and I’ve just noticed recently that Zipwhip is no longer sending out texts when my jobs are done. All settings appear correct. Is this a known issue or just wackiness on my end?
Ok, check it out now. Zipwhip changed its API calls to only allow HTTPS and I was still calling HTTP so fixed that and now it’s working fine.
Awesome. Will do. I’ve got a bunch of laser jobs to run this afternoon.
Cool. How do you run your laser jobs?
Jtech laser mounted on my CNC. Gcode typically from VCarve, then given to Chilipeppr and TinyG.
It works great! Thanks for the quick fix!
