Hello , thanks for letting me in. I’m trying to mill out a pcb that I’ve designed using fritzing. I’ve exported the file via flatcam to bCNC to send it to the CNC machine. On the display inside the bCNC the display lloks ok. When I send it to the CNC machine the tool looks like it’s following the copper lands ok. The only problem is , when the tool travels across it follows the dotted lines conecting the copper lands, but the tool doesn’t lift and then drop . The result is the PCB lands are milled out OK, but the dotted lines are also milled out. Is there anywhere in bCNC where the z travel height can stup up and down?
By the sounds of it, it seems like the problem is in the g-code generated from flatcam using your fritzing file. I would take a closer look there. Just a guess.
Are the dotted line used to show a conductor under the board? I use Rhino, and I could change the color of the lines and cut them to save a file without them. I know nothing of Fritzing or bcnc and can’t suggest any more than that.
thanks for the reply. I’ve tried adjusting the ‘cut Z’ and ‘z travel’ in flatcam and regenerating the .svg file , but it doesn’t make any difference to the z travel, the tool never lifts when moving between lands. I there any other setting that I’ve missed ? Included a screenshot
It looks like you want it to mill out the green areas but do not want it cut across/outside of the red areas, correct?
If there is a bug in the G-code generation, then perhaps the tool diameter and overlap options are the problem? As in, the overlap might be greater than the distance between the two “islands” to be cut?
Most likely: Could it be that the cut setting is “on the line” vector instead of “inside the line” vector?
Alternatively, it might be helpful to see the other options you have set above the Geometry Options.
I’d say you might want load your svg into easel, select cut outside the line and generate gcode there and see if that makes a difference. Easel is pretty simple to operate. You’d have to load in the material and tool specs as well as the depth of cut.
It is a pcb, then the green is what you’d want I think
Oops. You want to keep the copper traces on the inside of the red lines. I probably should have said:
Hi James K. , No I want to cut on the red lines to isolate the green lands from the rest of the blank pcb because I want to leave the maximum amount of copper on the PCB. It’s to act as a ground-plane. I can’t see any option in flatcam to set this , so I’ll send you the flatcam settings if you don’t mind . I sounds like you understand flatcam a lot better than I do
hi martin. thanks for the reply. Does easel run on Linux and is it an alternative to flatcam? Also I’ve had a reply from SirGeekALot. to save me typing everything in again , can you view that reply?
I don’t know anything about Linex. Easel runs Grbl gcode, so anything that you can run grbl gcode on will be written by Easel. I routinely use Easel to generate 2d gcode to run on my cncs. If you download the gcode, it will be in a download folder… at least on Windows. I copy the gcode to a thumb drive and run that from a laptop connected to my cnc. It may be easier to understand to use Easel, as it is designed to be pretty user friendly. Your SVG should load right in.
I most certainly do not. I’ve never used it.
Is there a way to save the flat cam file as an .svg or .dxf? If so, any CAM software should be able to generate proper gcode. I f I were doing it, I would use Estlcam and I would run an engraving toolpath on the outside of the lines. Then I would run a drilling tool path for the holes.
You can also surface scan (probe) the PCB first to ensure it is flat. If it isn’t, Estlcam will adjust the z heights s as necessary throughout the various areas of the board.
I don’t think jumping to a different tool is the answer but if it becomes too difficult it should not be too difficult to upload the SVG to this and see how it handles your pretty basic rquirement of cutting along the red paths: One of my favorite CAM tools has been Kiri:Moto. Love how well it runs in my browser(locally) and that the developer uses the tool and is super responsive to user inquiries.
BTW, I’ve been using only Linux for about 25 years.
Here is an invite link to the Kiri:Moto Discord server in case you want to see how support and commmunity discussions are going: Kiri:Moto & Maker Tools
https://grid.space/
Yes, Easel runs on Linux because it is just a browser app.
I’ve used Kiri:Moto, too, and can vouch for it. It even does double-sided CAM!
Can confirm. Stewart is right on top of it.
EstlCAM is another good one. But it is Windows only and it is not free or open source. But the trial is basically full-featured–not crippleware. It just gets an ever-increasing timeout each time you save the g-code, which is fair and really only very slightly annoying.
Just buying it relatively cheap. It is made in Germany but the web page has an English version and it is only $59 USD. I’ve used it to cut a couple of small projects. The tool library is done very well, too, IMHO.
estlcam dot com (I can’t post another link right now)
