Greetings and thanks for any help I can get,
I’m coming from the March3 side of CNC control and decided to switch when my board fried.
I’ve everything is mostly up and running but the z probe. I’ve looked through the config and it might just be that I don’t understand it all. When one zeroes the end mill, generally you have a contact plate that sits on top of the surface. In March3 you would have code that compensates for the thickness of the type of zeroing late one used. Where does one make this adjustment? What is the code? I saw that G30 Z# but I don’t think it does what I intend. Maybe I just don’t understand the description.
Thank you,
Best
Dimitri
Imported from wikidot
