Would this pump be good for air assist? https://www.amazon.com/dp/B004PB8SMM/ref=cm_sw_r_awd_C9HKvbS88KS0A
probably not great, hard to tell but it looks like a small tankless diaphragm pump so even with a long cable run they tend to have pulsed air flow, which isn’t terrible but not ideal. you can improve it with an airtank but better with a tanked compressor, something that can run extended periods of time. you do want a decent amount of airflow and pressure to blow away debris and assist the cut.
I am gonna try with an airbrush compressor…
