Would their be any negative side effects from using Adafruit's library and FastLED together?
Would their be any negative side effects from using Adafruit’s library and FastLED together? Reason being is that I am using an RGBW strip in a new lamp and want Adafruit’s library to control the white LED so the lamp can be used like any other lamp. FastLED would be used for any other LED animations etc…
I have both libraries currently running on a Adafruit feather with Bluetooth. I use buttons on the app on my phone to determine what animation I am running. So button 1 is all white with Adafruit library. Button 2 is doing a rainbow with FastLED. The colors are not right but I’ll worry about that later.
They should be fine together.
