Would anyone using smoothie for the Herculien be able to send me the smoothies
Would anyone using smoothie for the Herculien be able to send me the smoothies code for me to flash on to the board? I am close to finishing the printer although I have not been getting responses back when I send simple g commands. The printer can run the breakin code just fine, I just have problems when it comes to auto pid and other things.
@Gunnar_Meyers The smoothie config that I am using is here: https://www.dropbox.com/sh/383x6ziztxt6r3m/AAAm6J2C6wdX3QlaBZAVmnaFa?dl=0
However, it should be noted: You’ll have to make sure you are using the same pins as I am for the bed, the hotend (I’m only using 1 currently), the cooling fan, fan for the hotend, etc.
Rather than copying what I shared onto the SD of your smoothieboard(?.. the azteed X5 also runs smoothieware), I recommend you compare your current config file and make sure you understand what each is controlling.
