would anyone care to share how they fitted a plastic drag chain to a
would anyone care to share how they fitted a plastic drag chain to a k40 for carrying the air assist hose to the nozzle?
This one fit my tube. I screwed it to the top screw of the laser head and to the top screw of the X axis.
Fit in the K40 with no problem.
http://www.aliexpress.com/item/Free-Shipping-1m-3-28ft-7-x-7-mm-Cable-drag-Chain-Radius-15mm-Wire-Carrier/32464684482.html?aff_platform=aaf&aff_trace_key=e2846ee2a56c49859337f62054a4e047-1467010680089-03338-bAmQVJa2R&sk=bAmQVJa2R%3A&cpt=1467010680089&cv&dp=0&af=cc
That’s a decent sized one at 7mm x 7mm @Jean-Baptiste_Passan . I’ve been wanting something nice and small to mount the same way you suggested.
i bought the next size up (10 x 15mm) and fitted it using the screw you suggested and at the other end with a screw through the back wall - but at the furtherst point from the mounting position on the back wall it isnt flexible enough…is that the way you mounted it?
@Jean-Baptiste_Passan is it possible to show a photo?
Here are some photos, sorry for the quality.
https://1drv.ms/f/s!Akp3KOq2lNXJhNR69sV7gaTNlRPwrQ
i pretty much fitted mine like this
https://www.flickr.com/gp/25376817@N02/TWM9o8
but it wont flex at to enable the head to move to the extreme right bottom corner
@adrian_miles Don’t attach it to the back wall. Only attach it to the x rail. Then you leave enough slack on the right beside the bed for the y-axis movement.
@adrian_miles What if you moved the mounting point on the back wall more to the right? would that allow it to access top-left/bottom-left/bottom-right/top-right?
got it running just had to modify a couple of the links on the plastic chain to enable a sharper bend than normal
