Working on trying to dial in carbon fiber abs. Going well so far but I needed to add some extra restart distance to avoid gaps after retract. Anybody have any pointers for me?
Current settings:
70mm/S 85% outer perimeter
240c hot end
70c bed (for now, will go up but it sticks really well to PEI even at 70C)
5.5mm retract @ 60mm/s, 0.5mm extra restart distance
@Matt_Miller I will be honest, I bought some cheap stainless ones of aliexpress a while back when I got the deal on this filament (super discounted). I wanted to try it out first to see if it is something I would like. And I do, so time to get some proper Official E3D hardened ones now
Edit: Just re-read and noticed the comment about color. I guess that’s why the 3dxtech link is glass fibre as the carbon will always have black specs.
That one is glass fiber, which is an interesting idea too. This one looks like carbon http://www.3dxtech.com/carbon-fiber-reinforced-petg-3d-printing-filament/ Have you used their filamnet before? I’ve never heard of them. Of course there’s also ColorFab http://colorfabb.com/xt-cf20 which looks to be the same polymer. I thought Amphora was some “new” polymer? Is it just PETG or PET(some other modifier)?
Well I just found out the hard way they miss labeled it, and I’m printing carbon fiber PLA not carbon fiber abs. I was wondering why I was getting funny extrusion. Dropped the temp down to 205 and turned on the fan and getting much better results, unfortunately I have no use for PLA
@Jim_Stone there is lots of it actually. I like 3dxtech filament but I’ve really only printed a couple kg of the red stuff (carbon nano tubes) and a sample of their CF filled ABS. CF filled filament are definitely more problematic through 0.4 mm noodles though @Eclsnowman . They don’t flow so well through small nozzles. It can be worked around, but consistency is tough
I’m doing a crash course in CF-PETG this week. I am prepared with hardened nozzles and drive wheels, but the part is big and time is short., with no experience with PETG on this machine, hot end or extruder configuration.
@Chris_Brent I wanted to print a new carriage for my enclosed printer. PLA doesn’t cut the mustard when the çhamber is 50-55C. Plus I just tendnot to like PLA. It’s a preference really, back from my e3d v5 days when I used to fight jams alot.
@Eclsnowman I was given some test filament by William at http://INTSERVO.COM. It is something new they are testing, carbon fiber filled nylon filament. So at least very soon there will be carbon fiber in nearly all common filament types. Same proviso applies for all nylon, it will warp without proper environmental controls, similar but not as severe as ABS. You might ask him about it.
Prints very light parts even at 100% infill and it is much stiffer than straight nylon filament. Does need heat, had to print at 260°C.
Plus the video was interesting seeing how your two heatsink fans spin at different rates.
