Hi all,
I’ve create simple designs (circle with words) in Inkscape and everything is fine. Once I open the design in K40 whisperer, the vector cut line is all wonky, unlike the smooth line in inkscape.
Any suggestions how to ensure it stays smooth in the image when opened in k40 whisperer?
K40 Whisperer’s preview renders SVGs without antialiasing (vector cut/engrave lines are also always displayed with a width of 1 on-screen pixel). This doesn’t affect the actual geometry of the paths. They will look just fine when you cut/engrave them.
It is something that has always happened. I hadn’t really noticed it was on the image when I first started out, and thought as a newbie it must be something I’ve missed, something I’m supposed to do in the inkscape process or the K40 whisperer process. But as I mentioned it’s smooth lines in inkscape, but not inwhisperer.
If would, vector etch a 25mm circle and a 25mm square on a piece of wood. Do one set at 10mm/s and another at 40mm/s. Post pictures. Vector etch and cutting are essentially the same operation and this will allow us to see if there are clues to possible mechanical issues vs software.
Hi nedman
My partner pulled it all apart and found there was something behind the glass on the mirror which was impacting the cut and making it wonky.
Took it out and it cut super smooth.
Now its just spluttering a bit and dieing through the cut then starting up again after a second
I’m a little late to this thread, but I’ll throw my 2 cents in… I’ve had trouble with Inkscape producing unusual, imprecise vector cuts…I had to use it because I needed to make a specific, larger cut on an Epilog laser in our local library. I saved my design as a SVG file, loaded into the Epilog, and unfortunately wound up with a very imprecise cut that looked like a cheap scroll saw cut. I hashed through the problem, and I found that when I zoomed into my design at high magnification, the vector lines wandered back and forth. I never did figure out what caused it…Bottom line: it was something intrinsic to Inkscape or the file format, but not the laser…
I use Coreldraw at home and have never had a problem
