Just received a new tube today. It doesn’t work but after a raft of tests I think the old one also took out the PSU when it died. Meanwhile I’ve noticed a rather wonky metal collar at the cathode end of the tube and wondering if this is likely to be another problem? Should I wait for a new PSU and test it or just return it?
Thanks for feedback. Think I’ll return the tube. W.r.t. the power supply, it shows a power light and the fan and accessory power is present. I’ve tested connectivity and resistance through laser switch, test switch and potentiometer and they all seem fine. However, trying to fire the laser with the cover test switch or the PCB test switch (inc. bypassing safety breaker on the cover) does not even twitch the ammeter. Haven’t opened it yet to check for burns or blown fuse - I was gonna be sensible and wait for any latent charge to dissipate
