Hoping someone might have some insight. Noticed recently I’m getting a bit of wobble in my lines.
Since I’ve recently upgraded head and made a mounting plate from acrylic I’m assuming that is the cause.
Seems to only happen at higher speeds. Image above is at 225mm and I first noticed it on the dot test.
But don’t want to assume… I’m thinking of trying to make the mounting plate from steel so I crank down on the threads a bit more.
But could it be something else? Bearing, belt, etc…
Any help or insight appreciated.
