Please forgive the rookie level of understanding.
Thought it best to ask for guidance before making connections and powering up.
For me … pictures work better then verbal descriptions.
This is my version of a schematic.
Does it appear correct ?
Still confused regarding the water protection circuit.
Should it be connected to ground if not being used ?
Can a potentiometer be used in conjunction to PWM ?
Thanks in advance
Steve
This in the PSU connection
The pinout function list
Set up with C3D firmware and config
Here’s the config sample
Laser module configuration
laser_module_enable true
laser_module_pin 2.5
laser_module_maximum_power 1.0
laser_module_minimum_power 0.0
#laser_module_default_power 0.8
laser_module_pwm_period 200
switch.laserfire.enable true
switch.laserfire.output_pin 2.5
switch.laserfire.output_type digital
switch.laserfire.input_on_command M3
switch.laserfire.input_off_command M5
