NOTE: htt ps:[//] is because of low-karma user and is correct in the file. also the <dot>.
Here is a information of the failure:
Tue 10/01/2013 20:59:34.53 Starting .\win_install.cmd
Tue 10/01/2013 20:59:34.55 Executing build\win32\[curl] -kL0 htt ps:[]launchpad<dot>net/gcc-arm-embedded/4.7/4.7-2012-q4-major/+download/gcc-arm-none-eabi-4_7-2012q4-20121208-linux.tar.bz2
Tue 10/01/2013 21:00:26.18 Executing build\win32\md5sum —check C:\Software\GitHub\Smoothie\build\win32\gcc-arm-none-eabi.md5
gcc-arm-none-eabi-4_7-2012q4-20121208-linux.tar.bz2: OK
Tue 10/01/2013 21:00:26.55 Executing build\win32\curl -kL0 htt ps:[]github<dot>com/adamgreen/GCC-ARM-Embedded-20121208/tarball/master
Tue 10/01/2013 21:00:35.97 Executing build\win32\md5sum —check C:\Software\GitHub\Smoothie\build\win32\GCC-ARM-Embedded.md5
GCC-ARM-Embedded-20121208.tar.gz: OK
Tue 10/01/2013 21:00:36.18 Executing rd /s /q C:\Software\GitHub\Smoothie\gcc-arm-none-eabi-4_7-2012q4
Tue 10/01/2013 21:00:36.19 Executing rd /s /q C:\Software\GitHub\Smoothie\gcc-arm-none-eabi
Tue 10/01/2013 21:00:46.04 Executing build\win32\bsdtar xf C:\Software\GitHub\Smoothie\gcc-arm-none-eabi-4_7-2012q4-20121208-linux.tar.bz2
Tue 10/01/2013 21:03:36.51 Executing move C:\Software\GitHub\Smoothie\gcc-arm-none-eabi-4_7-2012q4 C:\Software\GitHub\Smoothie\gcc-arm-none-eabi
0 dir(s) moved.
Access is denied.
Tue 10/01/2013 21:03:36.53 Failure forced early exit
I have tried several time to install this software. But even by premaking the directories or not it will not install.
Bob Teeter
Imported from wikidot
