will this 3d printer project work.
3d pdf linked.
@Nathan_Walkner did you open it in actual acrobat an a desktop. Otherwise you cannot view a 3D PDF. I am on a phone now. I will look later today.
Quick look, three 90 deg bends on bowden tube? Think that spells trouble.
@Gustav_K_Gustavsson The 90° bends are just for ease of drawing, the path is horizontal to vertical from spool to extruder then a simple 180° arc from extruder to hotend, basically no different than nearly all other bowden equipped printers.
@E_Wadsager Can’t say much for the rest of the design, other than there is a lot of fabrication that needs to happen to build this, especially for the bed support.
for the bed support i will use
http://www.byghjemme.dk/images/MILLARCO_HYLDEKNAEGT-UPROFIL-ELG-p.jpg
they only need to be cut in lenght.
they 2x 90 deg. bends on the tube is of couse only on the drawing.
btw i use Selfgraphite bearings for x and y axis.
