Why would a PID auto tune fail,
Why would a PID auto tune fail, error says failed cuz temp is to high. When i turn the hotend on it will regulate the desire temp:ie 200c. Its just the AUTO tune that fails. I raised the #define PID_FUNCTIONAL_RANGE from 10 to 25 but didn’t change anything.
Is the hot at room temperature before you start the auto tune
Room temp. It over shoots the 200 mark to 250 or more then errors from that. The PID only starts working withing 10 degrees of the mark so i think it is just heating faster that the PID can take control. Maybe if i turned the max out put from 255 to say 155.
I’ve seen this happen before with heaters that are over-powered or have too much thermal isolation from the sensor so that the sensor’s reading continues to rise for too long after the heater shuts off.
There’s a hard-coded safety limit in temperature.c. Search for “PID Autotune failed! Temperature too high” in that file and look one line above it to find the limit so that you can change it.
I can not locate temperature.c.
But there is something else i see
The temp sensors should be -1 or just1
#define TEMP_SENSOR_0 -1
#define TEMP_SENSOR_1 -1
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 0
It should be set to the number corresponding to the specific thermistor that you’re using, according to the table in the comments directly above. -1 is “thermocouple with AD595”
Yes i was actually referring the the - in front of the number. The version i am using doesn’t have the - in front of the number or i have omitted it. I am using
#define TEMP_SENSOR_0 5
Could this cause a problem
#define TEMP_SENSOR_0 1
means something different from
both are valid options, but the latter is the default and most likely means that the configuration has not been properly set up for the machine.
Thanks for your input
The over temp error could be triggered by exceeding the max temp setting in Marlin. Had that when i first tried PID autotune on my E3D.
@William_Frick Pretty sure that error would look different. It would say something about MAX_TEMP instead of saying that PID autotune failed.
@Whosa_whatsis It was a couple of months ago … you are probably right.
@Whosa_whatsis I was finally able to get into temperature.h and change the max temp from 20 to 30. That fixed the over shoot and i was able to complete the auto tune. Thanks!
