Why does this keep happening? Mid print,
Why does this keep happening? Mid print, it just stops printing and I can’t push any filament in through the hotend. The hotend shows that it’s 230 some degrees for Hatchbox PLA.
Sometimes with PLA going too slow can be a problem on all metal hot ends. Can you put some of your settings to help us troubleshoot?
My setting for hatchbox pla is 210. and printing very well. maybe you can try it.
Any cold extrusion prevented error show up on the controller? Hoping the hotend didn’t fail to keep up temperature.
[filament:Hatchbox Filament]
bed_temperature = 0
bridge_fan_speed = 100
cooling = 0
disable_fan_first_layers = 1
extrusion_multiplier = 1
fan_always_on = 1
fan_below_layer_time = 60
filament_colour = #FF0000
filament_diameter = 1.75
first_layer_bed_temperature = 0
first_layer_temperature = 235
max_fan_speed = 100
min_fan_speed = 40
min_print_speed = 20
slowdown_below_layer_time = 20
temperature = 230
[print:50 mms Speed 60% Infill W Brim]
avoid_crossing_perimeters = 0
bottom_solid_layers = 6
bridge_acceleration = 0
bridge_flow_ratio = 1
bridge_speed = 50
brim_width = 5
complete_objects = 0
default_acceleration = 0
dont_support_bridges = 1
external_fill_pattern = rectilinear
external_perimeter_extrusion_width = 0
external_perimeter_speed = 50
external_perimeters_first = 0
extra_perimeters = 0
extruder_clearance_height = 20
extruder_clearance_radius = 20
extrusion_width = 0.4445
fill_angle = 45
fill_density = 60%
first_layer_acceleration = 0
first_layer_extrusion_width = 200%
first_layer_height = 0.25
first_layer_speed = 50%
gap_fill_speed = 50
gcode_comments = 0
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed = 0
infill_overlap = 15%
infill_speed = 50
interface_shells = 0
layer_height = 0.2
max_print_speed = 80
max_volumetric_speed = 0
min_skirt_length = 0
notes =
only_retract_when_crossing_perimeters = 1
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhangs = 0
perimeter_acceleration = 0
perimeter_extruder = 1
perimeters = 2
post_process =
raft_layers = 0
resolution = 0
seam_position = aligned
skirt_distance = 2
skirt_height = 1
skirts = 3
small_perimeter_speed = 50
solid_infill_below_area = 20
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 0
solid_infill_speed = 50
spiral_vase = 0
standby_temperature_delta = -5
support_material = 0
support_material_angle = 45
support_material_contact_distance = 0.2
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_extruder = 1
support_material_interface_layers = 0
support_material_interface_spacing = 3
support_material_interface_speed = 100%
support_material_pattern = rectilinear
support_material_spacing = 3
support_material_speed = 50
support_material_threshold = 0
thin_walls = 1
threads = 4
top_infill_extrusion_width = 0
top_solid_infill_speed = 50
top_solid_layers = 6
travel_speed = 50
xy_size_compensation = 0
[printer:Eustathios Spider V2]
bed_shape = 0x0,285x0,285x285,0x285
before_layer_gcode =
end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\ng28 y0 ; home y axis\nM84 ; disable motors
extruder_offset = 0x0
gcode_flavor = reprap
layer_gcode =
nozzle_diameter = 0.4
octoprint_apikey =
octoprint_host =
pressure_advance = 0
retract_before_travel = 2
retract_layer_change = 1
retract_length = 8
retract_length_toolchange = 0
retract_lift = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 30
start_gcode = G28 X0; Home X\nG28 Y0; Home Y\nG28 Z0; Home Z
toolchange_gcode =
use_firmware_retraction = 0
use_relative_e_distances = 0
use_volumetric_e = 0
vibration_limit = 0
wipe = 0
z_offset = 0
Nothing jumped out at me other than perhaps an 8mm retraction which seems high for PLA. But I would say your speed looks fine so you are not going too slow. I would try shorter retraction, faster retraction speed, and going hotter and see if it still occurs. Also I recommend a nylon cold pull to clear out the nozzle just for good measure.
PLA jams are no fun. Perhaps 8mm might be too much retraction and could be causing hot plastic to freeze above the melt chamber. Do you have to disassemble the hotend each time to clear the plastic?
I’m pointing to retraction I could never get a good retraction with plans a Jam would be imminent
I lowered the retraction to 4mm and changed the retraction speed to 40mm/s. I have the temp set to 230 but while it’s printing, the temp is currently 225ish. Watching the temperature curve in Repetier Host, I don’t see the temperature dropping down below 220. It ranges from 223 to 230.
When it jams, I pull the filament out of the hotend and cut a piece of it off. After that I put it back together and push some filament through.
I ordered a new E3D V6 hotend yesterday. Might be overkill, but I’ve been using this existing one for quite some time.
I think it might be time to hand tune the PID. I am not sure if it has gotten better, but the autoPID tune in smoothieware never gave me very good results. I always ended up hand tuning PID to get fast heat up, responsive change on print speedup/slow down, and stable temps.
This graphic more than any other explanation I have found explains how to properly tune PID: https://en.wikipedia.org/wiki/File:PID_Compensation_Animated.gif
  • eric thanks for that wiki/PID link !
You might also burn out the nozzle…I use a butane cooking torch and a pair of needle nose pliers I don’t care about.
Check the fan that’s attached to the heat sink. Cooling seems almost always the problem with E3D extruders that have a jam after some time of printing. Make sure the lower part of the heatsink is well in the air flow. A new E3D extruder is probably not going to change anything (apart of a new fan that might work better).
