Why are my svg files scaled way bigger after importing into laserweb?
Its not making any difference.
Inkscape and also coreldraw, same thing.
Yes thats what I am doing.
Great. I gave up I figured out how to do it from the CAM tab instead, that works, sort of not sure if its accurate.
That would be great but it doesn’t appear dxf is supported or its buggy or something. I exported from microstation and corel and niether worked.
aahhh thanks exported from corel to dxf R11 works great.
I had that problem with INKSCAPE, fixed it by making sure the Drawing units was in mm not pixels and used 90 as the setting in LW.
