Returning (19/01)
Solved
While waiting for an answer, I kept my tests.
To be straightforward: I forced windows to use my Notebook’s 4 processors in msconfig (the option to keep the processor item unchecked that windws will manage this, for me it was not a reality).
Even so, I find this whisperer “difficulty” quite strange, since Meerk40t loaded the same file in a few seconds.
I will end up turning to Meerk since it has power control. Very attractive to me.
Thank you all.
Hello everyone.
Sorry for the long post. I tried to explain everything to facilitate help.
New in everything about laser. I received my laser in December.
My searches indicated Whisperer as the best to work with the Laser.
The weather forecast indication is sensational.
Excited and thinking about improving productivity, started using the page full of art (same drawing copied to the limit of my page, 600x400).
My problem: Whisperer crashes (keeps loading indefinitely) and can’t load SVG (more than 30 minutes waiting) when I put a lot of gear in the file.
I attach an example - I had a problem with several files where there are many drawings on the page.
In this file, I reduced the number of drawings and saved the SVG - 12, 11, 10, 9, with 8, loaded the SVG. It took about 2 minutes.
I don’t see it as a complicated art.
I used Corel Draw and Inkscape to generate the same SVG (as a test to exclude the generation error of any of them).
What should I adjust on the Whisperer? I wish I could upload more complex files.
Is there a limitation in Whisperer for more complex or larger files?
I attach the svg I can and can’t load.
I attached images of my CPU usage while trying to load the file.
Thank you all.
Forgot to mention: Version 0.55, 64 bits
When loading - I found that new users can only load 1 media …
I will keep the text with the indicative of the files if it is later enabled or if this post is released.
Obrigado ao Admin por liberar a carga de mais arquivos.
