Yep, we had a good little chat about that. For smoothie with a 80% limit set the power in LW to 1. I tried to set it at decimals and it would not raster anyway.
Ok, so it sounds like the scale slides. If I’m understanding correctly, there is still a difference between 80-100 if capped at 0.8 in the config. In terms of a gradient, we should continue to see an increase in power over 80% instead of 80-100 being exactly the same (capped)
