Which 24 x 48 CNC?
I need to make some custom wood block-type items that I believe a 24x48 size CNC would do well for, but I’m not up to speed on what brand or model would work best for me. It won’t be used in any kind of commercial way so it doesn’t have to be the toughest, nor is the work I have planned for it precision work so it doesn’t have to be the sturdiest either. A little discrepancy in a piece won’t matter to me. I’ll probably end up using 3/4" thick plywood and carve out blocks of about 20" x 3", and then carve shallow 1/2" slots on top of the blocks.
Any suggestion for an ok CNC for my needs? Should I be open to buying used?
Thanks much!
Have you considered a MPCNC or LowRider?
It is not quite out yet, but perhaps the Maslow 4?
Wait…this sounds like a one-off project. Are you sure you even need a CNC to make what you want to make?
