I kinda fell out of circulation there for a year or so, but I’m now in a position to continue my build. Divorce will do that to a person.
Anyhow, so I’ve noticed that it appears Ultibots is no longer around, and I’ve not been to successful sourcing the 10 mm sintered bronze bushings. Anyone know where I might find some?
Thanks in advance
McMaster, maybe?
amazon?
https://amzn.to/3frDf3U
Panel-Mount Oil-Embedded Sleeve Bearing, for 8 mm Shaft Diameter, 11.5 mm Long
Or
Oil-Embedded Sleeve Bearings, for 10 mm Shaft Diameter, 11.5 mm Long
Or
I used the ones from Stock drive parts recently, got them quickly and they fit perfectly.
Thank you all. This really helps!
They arrive Thursday.
I think I’m finally in a position to start assembly on this thing! 2-1/2 years later, I think?
