Where do I get exactly this PEI-sheet but without the ridiculous 25$ shipping?
Where do I get exactly this PEI-sheet but without the ridiculous 25$ shipping? I already bought some sheets a while ago and they are exactly how I want them to be. Is there another vendor for this out there?
http://shop.prusa3d.com/en/3d-printer-parts/109-replacement-pei-sheet-ultem.html
What I know all of them in Europe were bought by Prusa Research for MK2s…
@Rene_Jurack might want to check CShyde. They’re located here in the states but will custom cut a size for you without any provlems. Just make sure to specify you want matte side exposed.
Did you try Amazon? Amazon UK lists Gizmo Dorks PEI sheets, with shipping from the states under 3 pounds. Only checked the UK…
@Rene_Jurack did you consider to try Filaprint?
@Hakan_Evirgen No, I didn’t consider Filaprint. But I checked back regarding your post and found, that they sell Filaprint-printbeds “for the DICE” ^^ https://www.filafarm.de/products/druckplatte-fur-abs-und-pla?variant=23787590467
But 36€ is a pricetag of its own?! Worth it?
@Kirk_Yarina I checked, but they only list “trasfer tape sheets for PEI-sheets” as far as I can see.
Seems pretty pricey even for PEI. Are you looking for a quantity? If it’s the thin stuff, I know one seller that uses a guillotine paper cutter to cut larger sheets down to a preferred size, so you can buy larger sheets to cut into many smaller ones and pay for the cutter on the first sheet.
@Griffin_Paquette I should’ve mentioned, that I am from Germany ^^
@Jeff_DeMaagd Tell me your source, please :slight_smile: And yes, I am looking for the “thin stuff”. But I need the transfer tape on one side…
I probably shouldn’t say who I was referencing (I do work for the reseller , might be considered advertising) but they get it from here: http://catalog.cshyde.com/viewitems/3d-printing-materials/ultem-pei
If shipping is excessive I can probably get you some cut to size and mail it using First Class Mail for a more reasonable price.
@Jeff_DeMaagd Thanks for the link, the have same prices like prusa (good) and do ship for 15$ to germany (better).
Cool. I couldn’t beat that, that’s about the cheapest you can get. I never know if a business will require a more expensive shipping service or not.
I have several DDP already. I am satisfied with them, but other options are worthy, too. Prusa-PEI-Sheet for example has better stickyness the the DDP…
amazon.
@Rene_Jurack I have Filaprint and it is the best. When you stick to the manual it should even be as good as the lifetime of your printer. Of course not all materials are suitable but Filaprint supports more than others. E. g. Ninjaflex should not be printed on it as it sticks too much.
@Jeff_DeMaagd , I won’t consider it advertising if someone is looking for something you know is carried somewhere; even if you have a connection with them.
