When i import a eagle .brd file in CP, it writes an M6 command.
The line (in my case) says:
TO M6 (Tool change)
Is it T and the O from Otto or a 0 (zero)
Because in my case it is the letter O
It should be a 0, but since we don’t ask what tool numbers people have, it should also have a comment on what size it’s expecting at that spot.
@jlauer ​ Ok so than it is a bug in Chilipeppr?
So if i understand right, the tool-diameter should be after the T?
Because now i just get an error. If i change the ‘O’ for an ‘0’, the error dissapears.
