I’ve got a fair sized shop compressor that I’d like to use as a source for air assist on an ortur Lm3.
I’m planning to give the air assist its own dedicated feed with a pressure regulator just for the LM3 so I don’t have to keep changing the supply around.
Presuming that I’m mainly going to be making parts and scenery for models, and cutting 1-3mm ply or balsa, what would be the best “set and forget” psi to set my regulator to?
I’m using the factory default nozzle for the LM3. No modifications.
I obviously don’t want to just crank thing up to the maximum, I’ve got no way of determining the air flow, only the psi at the regulator.
It’s a large shop compressor with a large tank that was originally purchased for high pressure spraying. If I just leave it at maximum it will could possibly damage the laser engraver, or at least blow the materials that I’m trying to cut out of alignment.
You could ask Orturs support that question but I think you are searching for precision where there is none.
In my experience, the amount of airflow depends on the conditions at/in the cut. Various materials, various cuts, at various speeds at various thicknesses, and at various airflows produce differing results.
The psi that is needed at your compressor for a particular cut dynamic depends on the design of your air assist head, connections, feed hose, and compressor. So it’s best to just experiment until you understand the characteristics of your air system.
A common air assist pump is a Hailea pond pump or a clone. These are rated at 0.03Mpa, or 4psi. Ortur sell a pump which is apparently rated at ‘>= 0.003mpa’. The ‘m’ is probably an error and the number of zeros may be, too. And who knows what >= implies ?
I would start at 2psi and expect to increase it a little. You’re only trying to get the smoke away from the lens. If you can feel the stream of air with your finger, that’s probably sufficient.
We set ours anywhere from 12-20psi. If the parts blow around turn it down. Get a regulator with a moisture trap. Shop air can have unexpected moisture and water may damage your cuts.
