what is the name of this thing ? I want to connect steering block with the screw in the photo. If i screw it, suspension doesn’t work
You have to use ball studs, not screws
yeah ball joints are necessary here
I use screw’s on mine, however mine is the openRC f1 car. Screw’s work fine for me since it was a little right, I just worked it until it loosened up.
For the Open RC F1 it’s different, because this model don’t use suspension where the steering has to handle the movement. But the Truggy needs ball joint.
How axcactly can i use those, if i screw it suspension willl work but it is not going to steer
http://www.ebay.com/itm/Metal-Ball-Joints-Parts-RC-Car-1-10-scale-/262634778221?hash=item3d2640ae6d:g:mkcAAOSw4shX4X3z
I bought this ball joints from eBay made a small modification to the arm and it works great I can send you the file in gcode
http://www.ebay.com/itm/6P-Ball-Head-Screw-02038-HSP-Racing-Spare-Parts-For-1-10-RC-Model-Car/170792692335?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
yes sent it , i have left this in the middle…
