What is the best supplier to buy all the Herculien hardware from?
What is the best supplier to buy all the Herculien hardware from? Also is there a good place for all the electronics? I think I’ll buy the aluminum parts precut from Misumi.
Smw3d.com. The second supplier links on that spreadsheet.
Hardware as in nuts/bolts I would get what you can from http://www.trimcraftaviationrc.com/
They don’t carry everything on the BOM, but for what they do the prices are great, and good quality.
I’ve only seen the pdf which doesn’t have any links on it. The second BOM option will not load all the way. Which has true links?
@Gunnar_Meyers all the links are there in both documents. You need to click the suppliers pricing.
Thank you so much for the help. I hope your ready for more newb reprap question in the future. This will be the largest most complicated printer I’ve built and it’s great to see an active community behind it.
@Gunnar_Meyers I will help in any way I can. It is a complicated build… But worth it in the end. But I am probably biases :wink:
