What have I done?!
Took an hour and a half to unbox it in the back lane behind the house as I wouldnt go through the gate, then upstairs to the “office”. Some hastily moved junk from the desk as I was bigger than I was told.
Cat in the picture for scale…
If I ever move house its staying where it is.
Which one is that?
Its a 50W ebay machine.
The article says “350B 50W CO2 Laser” but its the same non-branded Chinese type Laser.
I had to wait in for delivery, then go to work when it didnt show up, then come back home for delivery again, now back at work so I cant even play.
I dont finish until 10pm so I’ll have to be tomorrow now.
How accurate this is I dont know… and im a bit worried now I didnt notice any pump/compressor or “extras” bag…
I did find the Rotary Attachment though.
Technical Parameters
Laser power
50W
Laser type
Hermetic CO2 glass tube
Power supply
AC110±10% 60HZ
Working area
300mm X 500mm
Max moving speed
500mm/s
Locating precision
<0.01mm
Min shaping character
Character: 2x2mm, Letter: 1x1mm
Operating temperature
5℃-40℃
Resolution ratio
≤4500dpi
Control configuration
DSP
Data transfer interface
USB(offline)
Worktable
DC-G350D –up&down table
System environment
WINDOWS 2000/WINDOWS XP/ WIN7/VISTA
Cooling way
Water Cooling and protection system
Graphic Format Supported
The Files which CorelDraw, Photoshop, AutoCAD can
identify(BMP,GIF,JPEG,PCX,TGA,TIFF,PLT,CDR,DMG,DXF,
PAT,CDT,CLK,DEX,CSL,CMX,AI,WPG,WMF,EMF,CGM,SVG,SVGZ,
PCT,FMV,GEM,CMX)
Compatible software
CorelDraw, AutoCAD(Not Included in this item)
Cutting thickness
0-4mm (depends on different materials)
Voltage 220V
Sloping engraving
Yes, slope can be designed discretionarily
Cuts off the water supply the protection
Yes
Packing
Plywood case
Parts
Cylinder Rotary Attachment
Machine Dimension
1020×650×630 mm
Net Weight
65KG
Does the cat come with it? LOL
Actually I’ve visited someone who has one of the 50w machines, it’s a beauty! I’m definitely thinking of picking that one up compared to the K40.
Seems to have everything you need straight out of the box
Yeah, the cat jumped out of the box when I opened it. I shall call her spring roll.
It might potentialy have all the bits straight out of the box but it needs some tidying and a bit or straightening before it could be used! Only been playing for 40mins but its full of the usual dust and warehouse material, floor sweepings and the like, and the bed is about 5mm out from left to right. Highest on the left hand side. Hopefully with the adjustable bed I can just undo the corner screws that raise and lower it and move it manually. Probably out back and front too but I didn’t check yet.
890GBP for that price you have good value for money.
most mod being done.
http://www.ebay.co.uk/itm/CorelDraw-AutoCAD-50W-CO2-220V-USB-Lsaer-Engraving-Engraver-Cutting-Machine/400970882686?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D33957%26meid%3D3aa2c75a8b1c4c2c9361ede08d67003d%26pid%3D100009%26rk%3D5%26rkt%3D10%26mehot%3Dpp%26sd%3D111809036078
I’ve been eyeing that machine for a while too, the K40 is cheaper, and smaller, but I’ve seen the 50w in person and it’s sure a beauty and has a lot of things right out of the box that one would have to mod the K40 a lot to match.
