What do you guys think? Fail, or succeed?
Fail:
• Scaled it wrong.
• Crazy 'do because of too much filament (didn’t measure after changing rolls) and Slic3r decided to ignore the 20% infill and make it solid.
• Forgot to turn off support. There is support under the chin that I probably can’t remove.
Succeed:
• Just look at it! It’s a tiny alien!
• The support material is a series of 0.5mm vertical lines. And they printed!
• Belt tightening removed the “ringing” I was seeing around corners.
