What are you guys using to glue acrylic together
Interested
Here is a link to what I have been using works great. SCIGRIP 3 10799 Acrylic Solvent Cement, Low-VOC, Water-thin, 1/4 Pint Can with Screw-on Cap, Clear https://www.amazon.com/dp/B00466V8F0/ref=cm_sw_r_other_apa_NhLQxbN9QJDBN
Acetone works best if you have no gaps in the material
Tensol 12
I use Chloroform… it’s the best solvent.
