What are the fastest ways to create the following STLs and eventually print them all?
I am producing 150 unique 3D-printed items for my wedding reception in late July. Each guest will be getting one of these but with a different word (Faith, hope, love, forgiveness, etc.) on it as a thank you. I’ve included the link to the base that I have in thingiverse. I am trying to use OpenSCAD to speed up the process but is there a way to link my excel spreadsheet to OpenSCAD to read the word, insert it into the favor, combine, and then export to STL? Thanks in advance.
http://www.thingiverse.com/thing:66519
Maybe script with a .batch file on windows or BASH on linux if you know how, you can pass parameters to openscad using -D
http://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General check the section at the bottom
The basic form would be:
openscad -o favor_James_Love.stl -D ‘word=“Love” name=“James”’ favor.scad
You can either produce that command line from within your Excel file, then copy that column and paste it into a text file to make a .cmd script, or you can export the Excel file to a CSV to read into some other scripting language to create and execute the commands.
Thanks for your help but I’m still having trouble. I’m able to open openscad from the command line but when I input the line it doesn’t produce anything. Here’s exactly the line I’m using:
openscad -o favor_Desire_Love.stl -D ‘word=“Desire”’ weddingfavorFinal.scad
And I’ve tried doing it from: C:\users\Chris_Reyes\ as well as the folder where weddingfavorfinal.scad is but with no luck. Any help would be greatly appreciated. Thank you.
Hey, Chris. I sat down and hammered through the issues, and I’ve got it working. Got a minute to hang-out, and I’ll help you get it working on your end?
The issue is that you are running on Windows, and windows has a flag in the file saying whether it is a GUI app or not, and for GUI apps, it does not connect the STDIO pipes.
Install Python, and use this script, modified appropriately (tweak of @nop_head 's script on github):
import sys
import subprocess
def run(*args):
print “openscad”,
for arg in args:
print arg,
print
log = open(“c:\downloads\openscad.log”, “w”)
subprocess.call([“c:\Program Files (x86)\OpenSCAD\openscad.exe”] + list(args), stdout = log, stderr = log)
log.close()
if name == “main”:
run(’-o’,‘test.stl’, ‘’’-D word=“Beauty” ‘’’, ‘weddingfavorFinal.scad’)
Check the openscad.log file for the output, and once you get it working, you can go on to reading in a list of words and calling run in a loop to produce the whole list of stl’s. (Hopefully google won’t smear the file too badly.)
Thank you so much. I just installed Python but I’m at work. I’ll ping you once I run the script. I appreciate the help.
