What are people using for power cut-off if the water pump fails?
Wiring diagrams greatly appreciated
I am using a flow sensor that triggers an arduino board to display a message on the LCD screen as well as triggering a 5V relay to kill the power to the laser.
@Phillip_Conroy let me know about these flow switches. I’d imagine you can just run them inline with the power feed to the laser tube.
I hooked mine up to the laser enable button low voltage do not hook upto high voltage at tube 22,000 volts ,will kill you
I bought a cheap flow sensor from lightobject and mounted it on the rear and wired it to the laser on switch. Works well for me. There’s a photo here. You can click on the link for a larger view.
@Phillip_Conroy Thanks for giving that extra info Phillip. Wouldn’t want any of us to get zapped.
