I was finishing up my custom panel for my emergency stop switch. I was just closing up the door and the bottom separated from the switch and arced on the frame.
Popped the 110v fuse.
Replaced the fuse and everything powers up, and I can test fire laser no prob.
BUT i have no computer control to cut or engrave…
Thoughts? and/or suggestions?
Any other fuses to check?
Kris
P.S. My wife thinks it’s a ploy to upgrade controllers… lol
You should have wired the E stop into the 5V control power.
But that’s not going to help now. Double check all the connectors to the PSU, one may have been pulled loose in the melee.
Beyond that, it may have killed the M2, but shouldn’t have if you simply grounded the AC mains to the cabinet. Weird things happen with a dead short, and currents can often go places you don’t figure they would.
If you have a meter, verify the M2nano is getting it’s 5V and 24V. (5v is the most important, the 24 runs the motors)
On the large white connector on the M2 controller Pin 3 is ground and pin 4 is 24v, pin 2 is 5v (pin 1 is the fire line, but it’s not in play here)
If the voltages there show 5 and 24, it’s probably the board.
Tell your wife we certify your innocence. (like that will help)
I removed the key switch (never gonna use) that was in series with the E Stop. They were wired in to the 110v circuit and kill the power to the entire machine. Should I disconnect from 110v and add it in series to the interlock system instead? just have it power off the laser?
Tested the M2 connector and I’m getting 23.8v and 4.9v
Checked and re-plugged all connections.
Checked and re-plugged USB connection
So I’m thinking the worst.
Where are you at with your ACR full kits?
Thanks for your help.
Kris
P.S. Anyone with a M2 Nano sitting around they want to get rid of for now?
I’d recommend, as you say, putting the Estop in the shutdown loop, hard power downs (fully loaded) of a switching style power supply like used in the tube circuit are harsh to say the least. The spikes generated can be damaging. (as I’m afraid you demonstrated)
If you need to do a stop, it’s nice to not total your PSU or laser tube.
I think the Manufacturer installs Estop buttons as on/off switches to say they have one. Done properly, there’s a master power and then a separate Emergency stop which breaks control power (machine circuits in industrial speak) If you want to stop the motors as well (advisable for a safety oriented estop) break the 5V supply. That will freeze all power releasing devices, but will leave the main PSU idling.
The K40 isn’t really laid out for a proper estop, usually the circuits are divided, and the Estop doesn’t crash the controller. It’s something I considered kitting, but there hasn’t been much interest. If you have the estop wired as a line voltage I’d only use it in a critical situation where property damage or injury was at hand. Chancing damage to your laser to save a sheet of plywood isn’t a good plan.
I currently have 1 available full kit (tetering as I have someone who just emailed me considering upgrading his older ACR - he was customer #2). And I may have another available but am waiting to hear back on his choice.
I also may have a original available but need to look into it. (I have one here that I forget what the deal is on)
The Originals go for $279.95 with a 3x, and the MarkII goes for $299.95 with the 3X. The 4X is +$25 and will be a few days as I have a shipment of those coming. Shipping is a flat $15
If you commit now, I can let you have the MarkII prototype and it will ship Monday. I’m going to hope this works out and nobody gets stiffed.
Drop me a note @ Scott594@aol.com
I resent the email to both addresses, the attached manual is going to the gmail address and is uploading now. it’ll be 1/2hr or so until it’s done.
Scott
@Scott_Marshall just checking in. It’s been dead silent on the email front. Nothing coming in via Hotmail and now Gmail has gone silent. Not sure if your just busy or if your email has gone totally wonky. If you need to contact me my phone # 1-403-596-1618. Cheers!
