Well I have just ordered: 1 of:
1 of: Improved 18mm ZnSe Focus lens (F50.8mm)
1 of: 18mm Laser head w/ air assisted. Ideal for K40 machine
Now the question is, is it possible for someone without any electronic training to upgrade the board, etc???. Or without any programming training?
@Tony_Schelts Changing the board isn’t a big deal. I agree without a proper tutorial, it look scary. but it’s something repeatable ( so no need of to be electronic engineer like +Peter van der Walt & @David_Cook ), just the inconvenience of fitting connectors and follow few cables, screws & nuts.
I did write my experience for other to look at
http://smoothieware.org/blue-box-guide
take it as a first attempt, hopefully more tutorial will come up.
And for the softwares it’s already there and easy to look at.
Thanks Stephane, I guess i better start saving. does the upgrade make he machine more versatile?
The upgrade increases the ease of use and reliability of the software.
Seems we had the same shopping list…apart from mine also included an air pump, tubing and a smoothie board plus some drag chain :slight_smile:
@Tony_Schelts my best answer would be to look at my today Workflow post
