Well i bought Coreldraw x7 home and student which is great, but when i run CorelLaser i get a CorelLASER error
The CorelDRAW(ver >=11) software not installed!
Any ideas???
will I be able to create files and use in LaserDRW? both cut and engrave?
Any ideas???
Tony,
The software kit that came with my K40 had Corel 12 included.
I couldn’t get it to work until I was clued in by I Laser and Yuusuf. They described the install process they used and I knew something was wrong.
I had used the Corel.exe file visible on the disk directory, and it seemed to install fine, but got the error as you did. Turned out the program installer is buried in a .RAR file which my file viewer (Free Viewer) did not see. I installed WinRAR (from the WinZIP folks) and there was the installer. Run it as with any installer, and you should be on the air with Corel 12. You will be instructed NOT to register it, and can’t. Use the dongle and serial number (same for all users) to activate it.
Yes, you will be able to cut and engrave and mark (never really got that one).
Corel is pretty tough to draw in, so you’ll probably end up drawing/composing in another package (I use Draftsight, because I’m a fossil from the Acad 10 days) and copying it into Corel via .pdf , .bmp files etc.
The same setup panel as in LaserDRW with the controller board number spot on top will come up when you go to laser. You set all the parameters in THAT box, not in corel. Power isn’t adjustable thru Corel either, there’s no hardware support for it. And Don’t waste time trying layers. (cut and engrave at once) They don’t work. At least not for me.
I’m Guessing the problem with your older version 7 may be compatibility with the laser driver plug-in that takes the Corel output and converts it to a controller compatible signal. It probably only works with >v12.
Good luck,
Scott
Coreldraw 12 is ancient Coreldraw x7 is very new only superseded by X8
That makes sense??. Show how much I know about Corel.
I’d try clearing it all out, loading the Corel x7, then run the Liytu (or whatever) installer. From what I understand, it loads the plug in if you already have Corel, otherwise it loads 12 and the plug in to match.
Sorry, I thought I had your answer. There’s got to be somebody here that’s running x7, hope they chime in.
Scott
I installed Corel 12 then X7 without issues on Win7 and 10.
I had no issues with x7 but it wasnt legit. so i bought x7 home and student now plugin wont work.
Thanks Scott for trying good group this is.
@Tony_Schelts did you reinstall Corel laser after installing x7?
yes.
It might be a case of Uninstalling it again. including laserdrw and perhaps corel draw, Reinstall CD and then CorelLaser etc.?
If the pirated version works use it, you are OK legally as you purchased an actual license for the software.
The pirated version is corporate and costs £500 plus. I purchased X7 home and student cost £67 big difference but plugin works with corporate only
Reinstall didnt work got an email of http://www.3wcad.com/ site and have tried emailing them hope they understand and respond
I think the difference is that the Home and Student version does not have Macro and VBA support. This is in small print on the bottom of the page.
"VBA / VSTA support
I think your right thanks for the suggestion .
