wanting to get a 3d printer …don’t wanna go to small whats a good printer I don’t mind having to build it as a kit if it saves me a buck or two
any info is greatly appreciated I advance…buying used could be a option too
You could consider:
For US$970.
Awesome specs vs price point.
I have a CraftBot 1st generation.
Thank you I will check it out
If you want something cheap there are numerous prusa i3 kits on ebay. Such as the folgertech. I would check that one out as well
get a prusa i3, nice and simple with a good build area
I have a he3d branded one, needed a few mods but now its awesome
nice thank you for your inputs after work I will check out these suggestions and youtube some videos on them
theres not much info on the he3d stuff though
thanks guys
Mendel 90? Designed by Nophead, hackable, well regarded among the community, and E3D (@Sanjay_Mortimer )even use these test their hotends.
It’s a bit “fiddly” to put together, but should get you good results
Printrbot Simple Metal is a good printer. That is what I’ve started with. It will do 6x6x6 inches. There is a upgrade available from Matrix Precision to allow you to print 8X8X10 inches for about $200. I highly recommend it.
I wish I had a second Printrbot Simple Metal so I could use it while I’m printing a 8-24 hour job on my other Printrbot Simple Metal.
Kossel (delta type) printers can be bought really big for cheap. try the Kossel xl on http://hkbay.com
Also rigidbot seems good and expandable.
Have a look @ " TeeBot"The suitcase 3D printer. http://www.3dstuffs.nl/teebot currently on kick-stater as a KIT or fully assemble and it is opendesign. https://www.kickstarter.com/projects/99905999/teebot-the-suitcase-3d-printer
@3D_ZPrinting I would like to be able to learn and adjust and be able to tweak when I reach that level just don’t wanna by cheap basic and the have to buy something everytime…if that makes sense
